Ok...In a recent inspection of the truck, I noticed that the U-joint at the transmission yoke (NV4500) had some play. I replaced all of the U-joints and centre support bearing around 50K miles ago (in 2011) when I bought the truck. (136K miles). More importantly, I notice play in the output yoke and the main-shaft. A bit of background of the truck:
If the replacement of the main-shaft is recommended, then I will do an entire transmission overhaul. Unfortunately, this is my busy season, and down-time is not really an option. I am not one to do "pity-Patches" either...HELP
I use the truck for relatively heavy hauling; over 7K tonnes. (That would be over 12K pounds in the States, including load on the truck and the trailer. Needless to say, I will not be doing this until the issue is resolved.
I have included a picture of a "light" load. In the coming months I have several projects in Holland, where I will be required to haul over 15K in Material including truck load and trailer. Thanks for your help. Jonathan.
- The truck comes from Waco Texas, and had a fifth wheel before the PO bought it with 100K on it.
- the PO was/is a bit of a yahoo, and never knew about the maintenance of the trans and rear, as per fluid change intervals.
- The rear seal was weeping when I did the drive shaft overhaul.
- Now the leak is of the dripping variety.
- Is it typical for the yoke to wear, or must I consider changing both the Main-shaft and yoke.
- I have very seldom seen a U-joint fail at the trans when there is a centre support bearing; what is the cause?
- (Info
A bushing (tail shaft bushing) is already on the way. Damn Fiat! Few parts are available here (in Germany) for the truck any more.
