Please help before I blow this truck up
P2563 Turbo Position Sensor Circuit Performance
'Mopar" Diesel Oil?
I paid them, and I do contracting work for the dealer. So I got it done. Anyway it had 4 TSB's that were taken care of. At this point, I am offering a $400. 00 reward, or a set of Flex-a lite fans for the CTD if someone fixes, or gives me the right pathway to get it fixed. My truck is my life and besides my family, it is the only thing that makes me happy. Please HELLLLLLLLLLLPPPPPPPPPPPPPPPPPPPPPPPP
~200 miles to the east of you is Mass Diesel. Scott is an amazing trans guy and may be able to sort out your mess.
The P0868 is a transmission low line pressure DTC,The P0871 DTC is a Overdrive pressure sense curcuit issue. The first thing I would recommend checking is the sump filter Gasket. If the sump filter gasket/seal is installed wrong or cut while installing the filter it can cause both of these problems. The next thing I would recommend checking is the spin-on (converter filter) filter, Make sure it is tight.
Mike
