I'm trying to track down the source of my 0 fuel pressure problem. So far I have replaced the fuel filter and lift pump. The filter was clean and the fuel was not jelled. The truck starts but runs rough when the pressure drops to zero, and runs fine when the pressure is fluctuating between 1-3 psi. Here's the odd part - if I bump the engine to run the lift pump on it's own, I can hear it running normally, and it pumps 15psi as normal. I opened the filter canister drain and it was pumping a fair volume. For some reason it is either not operating or operating at only part capacity when the engine is running. Ideas? I'll do anything to avoid taking it to the dealer. I actually think I know more about this engine than their diesel mechanic. Thanks
