Please help
Headlight Revolution HID low beam conversion kit
Ignition switch problem 2012 Ram
larryq
Tomorrow I plan on replacing my entire fuel rail.
Today I washed everything down to keep things clean, and started looking at the job.
I believe I can do it, but there is one thing that needs to be moved in order to get the back tubes.
there ia a LARGE wiring terminal block mounted to the Cowling, Over the fuel filter that needs to be moved away in order to reach the rear fuel tubes.
I cant for the life of me figure out how to remove it!
I don't see any tab to depress or anything.
when looking at the truck from the front the right side of the block looks pretty closed off, and from the left, there are holes , but they look like parts of the cowling mounting point.
Can anyone tell me how to remove this thing without breaking it off??
Thanks So much
Larry
