I installed the Fass 95 with the 3 micron filter and followed the directions on the install and when I was done I stepped back and looked at it and thought "Why the heck did they bypass the stock filter housing?". The OEM lines are just sitting there and are sure as heck mounted better/cleaner than the add on Fass lines and the housing has the fuel heater.
I found this and I'm curious if anyone has used it to get their Fass system routed through their stock filter housing? If so, did you have to remove the stock lift pump?
Thanks,
Glacier Diesel Power - Product Detail
Thanks,
