Justin, it's hard to explain the fueling possibilities with a box over the net. The basic limitation is that there is a solenoid on the VP44 that is controlled by the ECM (and by fueling boxes) - the longer that it's open the more fuel is put into the cylinder. However, the longer it's open the more heat is generated in that solenoid and the greater the chance for a melt down, also the further the slide will move in the rotor in the VP44 - Blue Chip diesel has a great explanation of VP44 failures with boxes at
http://www.bluechipdiesel.com/Bosch-VP44.htm . The true limitation of our VP44's is the solenoid duty cycle - you can increase the fueling of your box ridiculously down low and hit the wall on the solenoid duty cycle early and maintain that fueling level, or you could have it more level. Any of the boxes out there could set the max duty cycle at any level they wish - it's just what they feel comfortable with regarding heat in the solenoid! The max that I've been told they recommend is a 55% duty cycle before it can possibly get too hot depending on how long it's run. I have my box set at 70% - but I am aware of that and use my right foot to back off, but I am taking a risk. Tom and I are both running custom boxes that aren't normally sold over the shelf from TST. Both of our boxes do 100% overfueling at low boost #'s (to help spool the turbo fast - but also means TONS of smoke at low boost #'s) and then back off to 50% overfueling - comp boxes continue at 100% overfueling, however once the max duty cycle is hit then fueling is backed off. I had the fueling levels set on Tom's box so that his max duty cycle was at 60% (because he was concerned about his injection pump life) which was about 2500 rpm. In my case I have 4. 10 gears and hit 2800-2900 at the end of the 1/4 mile so I have my max duty cycle set at 70% so I would have full fueling until I was through the lights - but I'm taking a risk. Send me a PM or an email at -- email address removed -- and I'll send you my phone # and I'll be glad to discuss with you your options! Just remember that there are risks when you push the limits - myself, I decided that I didn't care about my VP44 warranty and was willing to take some risks on it - buyer beware and remember that YOU are your own warranty station!
