PML Diff Covers -- spare tire clearance?
Dynatrac Kit
05 & 06 Headlight Assy Interchangeable?
I am thinking about getting a PML diff cover. The PML cover sticks back further than the stock cover. With my camper on the truck my spare tire is about 1 inch behind the stock cover. Will there be enough room for the PML cover or will it hit or rub on my spare tire?
If anyone has a PML with their spare tire down behind the diff cover I would like to hear what they have to say about the clearance. ( or anyone else that may have some info on this ) If you know how much further back the PML cover protrudes I would appreciate your input.
Thanks,
Big Rig
mine clears fine. even with trailer attached. mark i have a question for you if you would be so kind:my pml has some seeping around the level ckeck plug,the fill plug,and around some of the perimeter bolts. i torqued the plugs to 12 lbs and the cover bolts to 20 lbs as per instructions. the gasket was fine as this was the first change.
JValdez said:
Big Rig,
I've got the PML covers with a 315 spare and it doesn't rub at all. I don't think you'll have a problem.
What about the Mag-Hytec with a FULL size apare? My stock spare looks like it would hit in the right situation???
thanks mark. should a guy use any thread sealer?i didn't because it didn't say anything about it in the instructions. its not gripping or anything it just looks ugly.
mattk50,
I had the same problem with them seeping. On the level and fill bolts I used a little silicone towards the tops of the threads. This kept the sealer from getting into the oil and worked great. On the mounting bolts I just kept giving them a little torque until they stopped seeping and this worked great as well.
RonCar,
I don't know about the Mag-Hytec. I think I was told they would rub but I'm not sure.
