I'm moving this question I asked BushWakr to a new topic. I got the POD's injectors in with few problems, BUT, my truck smokes like mad now. Not just at idle, but also running down the road, warm or cold. As far as I know, the pump had never been tweaked ( I never tweaked it, I puposely left it alone in anticipation of installing different injectors). From a reply by BushWakr;
"I had POD's put in a couple weeks back. I had some smoke at idle issues which were corrected today. Seems they came with the wrong washer thickness. Piers put in a brand new set, new washers, (thinner) and presto"
I installed the thick washers, the same that came off the old injectors. Also, my Cummins book called for 0. 06 in. thick, which are the large washers. Are you saying I have to run the medium thickness washers or the thin washers? And is a pump retiming necessary? Any help is appreciated.
