Will this cause too high EGT temps? Right now with my pump cranked pretty good I can max it out at 1200 deg and max boost is 27#. My pump settings as follows. Smoke Screw +2 turns; Diaghragm pin set at max; starwheel +2-3 turns; full load fuel screw +3/4 turn. Advice? Wait, make that 1300-1400 deg and 33#
of boost! I turned the full load smoke screw up some ? I'm not sure exactly how much? It was hard to count how many turns it went when it took it out to take the stop collar. I'm guessing 1-2 more turns. Man this sucker will RUN!!
Smoke and smoking burnouts.
Steve
Steve
