Engine/Transmission (1998.5 - 2002) Poll-Pump & Fuel pressure
Engine/Transmission (1998.5 - 2002) Is this the VP 44
Taking A poll on fuel pump and fuel PSI you all have and psi you all are seeing :)
What pump are you running :confused:
How much fuel pressure are you running :confused:
How long have you had the pump and been running that PSI :confused:
Im running 135A fuel Proporator @ 18 PSI
While Towing A 28' toyhauler PSI is 16 PSI
Since 3-1-2004
Thanks
David
Relocated OEM LP to frame rail, have added Carter 4600 pusher pump and also Frantz sub-micron fuel filter. PSI measured at VP-44 varies between a max idle of 22-26 depending of type of Frantz TP cartridge in use, runs 16-18 at freeway cruise, and WILL drop below 10 PSI towing 5er up a grade with a more restrictive TP cartridge, but normally runs no lower than 12 PSI under heaviest load - that's with the Comp on 5x5...
Been running the pumps since truck was new - no problems with either of them - the Frantz filter was added about a year ago...
RASP
idle 13. 5psi 2k rpm 16psi (VP44 bypass set @16psi)
2 years
pump pressure poll
16psi while idling or towing flat will slightly decrease when towing up Grocer's grade(6%) with 5ver. see ya! Oo.
Running 14. 5 Idle - 13. 5 65 MPH - 11 WOT. Have Vulcan Big Line Fuel Kit, I am using a NAPA OEM pump which is the same Carter as stock. I haven't pulled the trailer yet to see how low it will go.
Running retrofitted in tank pump, block mounted cummins campaign pump. 15-16psi @ idle, 13-14psi @ cruise, 11-12psi @ WOT. Been running this setup about a week. Waiting for warmer weather to switch over to the glacier pump setup.
RASP pump... 12. 5 at idle and 15psi at WOT... 180. 000 miles and still on the org. VP44... ... knock on wood :-laf
2 years and counting
Scott
Pressure gauge isn't as accurate as I'd like (reads low)... pressure is around 18, never goes below 16 psi... walbro 392 w/vulcan big line kit... I intend to turn the pressure up some...
FASS 150 13-15 psi idle, 12-14 cruising, 11-13 wot, depending on outside temps (colder= higher psi) all new line from the tank to the pump, through HF6604 (3 mic) been on my truck over 2 yrs. Still no probs, no on wood... ...
Stock lift pump in stock location, big fuel lines and DD pusher pump kit (Carter 4600) on the frame rail. 21-22psi at idle, 10-11psi WOT at 515rwhp. Lift pump is the original one. Pusher has been on since 36k. Truck is now at 96k.
FASS with 1/2" fuel lines (including tank pickup). Hot Rod VP44 with very large injectors and a Comp TST Fuel box.
I see 18psi Idle, 17 during drive and never below 16 @ WOT. If the gauge drops below about 12 at WOT, I change the filters.
vulcan kit
the Vulcan LP relocation kit gets me 14psi idle 10psi idle With comp on 5x5
stock was 12psi at idle and 3psi at WOT :eek: :eek: :eek:
Since 3-1-2004
Thanks
David
Glacier GFS-392 + 2 Micron Filter and in-line pre-pump filter/screen
18-19# idle & cruise, never less than 16# WOT & comp on 5/5
Since Spring 2006.
FASS 150/150 1/2 Lines 15. 5 WOT 20,000 lbs 13. 5 to 14. Two years and 450,000 Km on the pump. Did Brushes at around 350,000 km on pump. Still love the pump but the motor is on its last lag.
AirDog FP-80, 16 psi. @ idle, 14 psi. cruising @ 70 mph, 12 psi. minimum floored to 115 mph. It's been on for around a year and about 3000 miles.
I have the stock lift pump for now. 12 psi idle, 10psi at 60mph, 7psi WOT. About to iinstall an Airdog! Have been running this pump for 6 months.
I saw 15psi (at the filterhead) running a fresh OE replacement pump... it would eventually "wear" to 10 psi and that was also dependant of ambient temps...
I think my dad's truck is running about that using a campaign pump...
steved
