I started my truck for the first time since a facelift that started two years ago and during the reassembly I used polyurethane bushings and mounts everywhere. Starting with the engine mounts, the transmission mounts and finally the cab mounts. What was once the smoothest Cummins I had, is now vibrating quite objectionable at idle. I also upgraded the injectors and I did put a new hamonic balancer on it. Has anyone else experienced this with polyurethane? And if so do they soften a bit or do I have to go back to rubber?
