Have you noticed that your A/C just doesn't cool very well when the ambient temp is over 90F or so? Mine's done that since new. But it doesn't do it any more!
What changed? Well, just before I left for Muncie, the A/C stopped altogether. I figured it was low on R134 (4. 5 years, 110K miles), so I put a few ounces in. But still no joy.
So I traced all the wiring and determined that the low pressure switch was malfunctioning. I took it off, shook it, poked at it, banged it, shook my head and put it back on. 'Lo and behold, the A/C works again. And now it cools well up to at least 95F. Driving today in temps up to 90F, I still had a couple clicks of heat to keep it from being *too* chilly.
I've driven 2500 miles now with it on and no problems as yet. I suppose I should remove some of the excess R134. I've noticed that the compressor doesn't cycle on and off any more (except after a long period of idling).
So what changed? Perhaps the few extra ounces of R134 is preventing the low pressure from dropping below the switch's cut-off value. Perhaps poking the switch and banging it loosened it up so it doesn't shut off at such a high pressure any more.
If your A/C isn't working very well in high temps, you might try changing the low pressure switch. Or just banging it around a bit. (Beat it into submission?) If that all fails, you could put an extra ounce of R134 in it. Or two. But only at your own peril.
Can one get a low pressure switch that works at a lower pressure?
Fest3er
Fest3er
