I recently was driving down the highway with my Cummins diesel truck. The truck started making noise, I thought it was a wheel bearing, driveshaft, etc. I was watching my gauges and they were fine. I pulled off on an exit and my check gauges light on the dash came on. It was only about 2-3 seconds later and my oil pressure dropped to zero. I shut the truck off and got out and opened the hood to find oil down the side of the truck on the same side as the turbo. I was towed to the nearest Chrysler garage and found out the next day that my oil filter came loose and blew the seal out and all the oil in the engine. I'm currently getting the motor rebuilt. All the damage was on #6 cylinder. The crank had to be turned . 010", replaced 1 piston, and had to bore and sleeve one cylinder, and purchase a new cracked rod. The Chrysler garage where I had my oil changed last refused to cover the damages. They have since sold the dealership. Chrysler corporate could not do anything about it.
I would like to advise everyone out there to get a mechanical oil pressure gauge installed on your 2004 trucks. The current oil pressure gauge is electrical and runs off a resister on the alternator, it's useless. It does not indicate oil pressure. The check gauges light comes on when you are down to 2-3 pounds of oil pressure, my engine was already knocking before this light came on. Then the oil pressure gauge 2-3 seconds later dropped to zero. The gauge only reads 40-50 pounds but the cummins diesel runs 75 pounds. At least with a real gauge you might have a chance at saving your engine. This happened to me on 2/6/05 and my truck is still in the garage. They now have electrical problems and have ordered a new computer for the engine. The electrical they are covering under warranty. I have 38,000 miles on this truck and the extended warranty package and the engine was not covered, so buy a mechanical gauge for your truck.
Part of the reason the engine took so long is there are no pistons available for this new engine. I'm probably the 1st one in the country getting this engine rebuilt. They still won't be available till the middle of March at best. A diesel specialist shop gave me a couple of phone numbers direct to Cummins. I talked to a customer service rep. and he made a call to another Cumins dealer and he located a piston with a different ring set/part# but the same piston. Cummins was very good, they said if I could not locate a piston, they would take one off the production line and ship it the same day (Great customer service by Cummins!). Nobody from Chrysler would take that extra step to help.
