well guys, I did it... I actually tweaked my pump... I can't BELIEVE I waited almost 9 MONTHS! LOL! but this is my first Cummins and I spent real money on it, and I guess I was just operating under the "if it ain't broke, don't fix it" mindset...
I turned the full power screw up ~1. 5-1. 75 turns (not sure as I removed the entire thing to get the collar off... I marked everything as best I could... it might actually only be turned up 1. 25-1. 5 turns, but I'm not gonna push it till I get an EGT on it... I figure I should be safe at this level... no heavy loads or anything (certainly not till I get an EGT on it!)
I also just HAD to turn the smoke screw up a little!!
I actually turned it up 2 turns before I touched the power screw... I turned it back down half a turn after I turned the power up... w/ the 21cm housing, it'll belch a NICE cloud when you romp on it (hey, just doing my part to curb the west-nile virus problem!
funny thing, when I turned the power up, I kinda freaked out when some fuel trickled out when I removed the thing... I got it back together and the truck wouldn't start!! :--)
I seriously almost **** a brick... I was like "you DUMBASS... you're leaving for Colorado in 4 days and you just BROKE your truck which you have essentially NO experience with!" popped the hood and noticed that one of the plugs had come off the shutoff solenoid! LOL! WHEW!!!
what can I say? I LOVE It... the truck is much more responsive, and I can drive it with barely a trace of smoke, but a nice cloud is just a romp on the pedal away...
it's dark out, but I'm not seeing anything under full power... I'm scared about EGT's w/ no gauges, but like I said, it's probably only 1. 5 turns up and I've got a straight mandrel bend 3" system from turbo to tip (actually got a 4" tip, but... )
when I get back from Colorado next month, I'm gonna pony up for an EGT (I need one for my hot-rod too, so I'll just get one box and two probes) and finally install this 12cm turbine housing I've got and probably go ahead and put a full 4" exhaust on the truck...
I can't really run the truck hard down low as my transmission is crippled (holds gears too long... but I've been babying it for ohhhh about 25k and it's still going) but it's great on the highway and certainly more responsive around town!
does anyone see any problems w/ all this? I realize the 21cm housing is limiting how much fuel I can give it, but I'm under the impression that 1-2 turns is safe w/ my exhaust... I also realize the 12cm housing will probably hurt me a little on the big end, but it'll be more responsive around town and should blow a little more boost in there allowing me to crank the fuel a little more!
my H1C is still in GREAT shape... I inspected it earlier and the shaft spins like it's got a ball bearing center and has VERY little play! but... I have been thinking about an HX35 if I can score one cheap...
ok, I'm rambling now... time for bed... I'm just excited that I finally took the plunge!
Forrest
Forrest
