Popping noise from frt when turning???
Order Status Question
Warranty ? On Drive/fog Lights
I have been getting a loud popping noise from the front end when I turn into an area that has a incline and a turn... most drive ways. Any ideas?
Well may sound kind of odd, but I had the same noise under the same situations. Then I went off-roading, where I got the suspension really working. After that the sound went away. I know it sounds starange, but I don't have the noise any more.
I had the same problem. It was bent swaybar end links that were hitting the springs. The fix was lengthening the end links. I think lowering the sway bar with some of those blocks from Kore would probably also work.
Look at your trailing arms, if there are shiney spots where the paint is rubbed off you have a clearance problems with your 37" MTRs.
Terry
All good sugguestions. I had the links that connect to the sway bar repaced... they were bent. This is a popping noise like somthing is bound up when I turn and hit that incline. Probably a U joint... the one in my 03 also went bad. I do 10 miles of off roading every day and had to have it in 4x4 this am just to get out of my driveway. I already have the KORE drop blocks, so that aint it... hummmmmm
