Anyone have experience with these type setups
http://www.woodmizer.com/configurator/models.aspx?models=4
Thanks
BIG
Thanks
BIG
I don't have any experiance with their portable saw mills but I did have one of their fire wood processors with a 3 cylinder Kubota diesel, the automatic in feed deck and 6 way splitting head. It was a well made piece of equipment. I also want a small protable mill so I have done a bunch of research about them, including Timber King, Cook's, Norwood and Hud-son. I know you do a lot of reseach so do your homework and watch the video's. They all seem to have pro's and con's. Get the biggest and best with the most options that you can afford right from the get-go. I can only afford the most basic smaller units in the 5-7 thousand dollar range. If I were closer I would hit you up for a job running yours:-laf
Do you have some private timber or do you need to go on the forest?
Nick
If there is a small sawmill in reasonable distance it may be cheaper and easier to haul the logs for sawing. Many sawmills have closed so that may not work.
Most sawmills are very leary about sawing logs brought in from private owners. I'm sure your logs would be clean, but he doesn't know that. If you had ever seen a circle saw or band that hit metal or hidden debris( mostly dooryard or fence line trees) you would understand. It ruins expensive parts and can injure wokers. If you think your primary needs will be dimension lumber, look at Lucas Mills. They use a circle blade and set up over the log. They are a lot faster and also easier to learn to use efficiently. The downside is no wide boards. An added benefit is the initial expense is a lot lower.
