Porting, cam timing, and air flow managements systems are fundamental component of any total package program. Remember that a basic concept of any internal combustion engine is nothing more then an air pump.
The fuel system is only there to heat the air and cause expansion in the combustion chamber, driving the piston down producing usable rotating energy. Fuel must be introduced in the right amount, and at the proper time to produce the most efficient use of combustion expansion.
On a side note, initiate this process to soon for the given RPM and nothing can hold the combustion in, IE head gaskets, rings, and pistons. Start the process too late and you give up the potential power, and have residuals burning as the gasses go out the exhaust valve, giving some big EGT numbers. These optimal timing points change significantly with different acceleration rates, Pro Stock or Competition eliminator applications , go to the extreme of having a different tune for each gear and corresponding acceleration rate. REV GAIN
Cylinder Head porting dramatically reduce restriction in the intake track, and lowers temperature that go with excessive boost. . Big boost numbers are like watering the grass with a garden hose, put you finger over the end of the hose, and the pressure goes up and actual quantity of flow goes down. To achieve the same flow you have to raise pressure significantly. Creating heat and load on the turbocharger, and restriction on the exhaust track.
Over the last 10 years I have taught Fire flow hydraulics in fire fighters rookie school. This is a critical element for any firefighter; involving flow of water thru fire hose and other fire appliances. A critical part of fire hydraulics is friction loss. Air is a fluid also. There come a point where 150 lbs of boost doesn’t really move any more lbs of air then 75 lbs of boost, when you take in to consideration that the air in the intake track is closing in on 1000 degrees, Remember that an internal combustion engine, runs on the expansion of combustion gasses in the combustion chamber. Start these gases out at 1000 degrees, and you have less opportunity to let them expand even farther.
A good Example is my Cummins, it made big power on 35 to 40 lbs of boost; reason is that the cylinder head flowed almost twice the cfm of air as a stock head. Ray Little at RayMac racing engines, did extensive port work, and R&D on that cylinder head. The heads he is now turning out show even more improvement. Ray has had to hire an additional cylinder head flow specialist. This specialist came with a enthusiast attitude, and spends 10 hours a day 5 to 6 days a week developing their cylinder head programs
Again if you really don’t want big power don’t port.
