I just became aware of the Posi Tap and Posi Lock connectors, Thinking of going that route with the in cab splice onto the 18 ga ignition controller cigar wire.
Anyone have a thought about them or have you used them ?
Seem that a nice feature is you can remove them if required I don't think I would use them in an area that is exposed to moisture though they do have a waterproof butt connector that should work for wet connditons
http://www.webbikeworld.com/r2/posi-tap/posi-tap.htm
Manufactures site below
http://www.posi-lock.com/posiplug.html
