Have a 93 with about 170k on it my son has been driving for the last year. Runs good but has always had more of a rough idle than we thought it should. Advancing the timing seems to smooth it out a lot.
Long story short LP died, and power was down after a new pump. A rebuilt VE and we ended up with a dead cylinder, the clatter, and a miss in the video. Changed HG, all the cylinders looked good, nothing that would point to damage. Valves water tested tight.
Still the same dead cylinder in #3 and now the clatter is getting worse. Pulled injectors and pump to another engine and they run like a top with no problems. Checked pushrods, vlaves springs, etc. NOTHING that stands out as problem.
Sooo, thinking possibly a bad lobe on the cam, a bad tappet, partially sheared crank key, or ??? Sounds like a bad cam lobe and a collapsed lifter on a gasser. Compression tester on the way to rule out valves, springs, rings, etc.
Any more ideas?
Thanks
Alan
Any more ideas?
Thanks
Alan
