Engine/Transmission (1998.5 - 2002) possible Changes to my NEW truck ?!?
I have a couple elementary question about the new truck...
Does it help with air flow to remove the tube that connects the air-box to the fender?
And how long should I wait till i RE-HOOK-UP my Edge Comp to the the new truck ?? (has a whopping 198 miles on it now)
Finally, This cannot be helped now... BUT, was it a stupid move to get the 4. 10 gearing? I got it cause I want to put 35's on it later and the expense was only 44 dollars now OR alot more later to re-gear both ends...
BUT the truck spins up to 2300 at 70 mpg or so, I am a little worried to run engine that hard with little or no load...
comments/questions welcome
ALMOST FORGOT - is it normal for a new engine/truck to not idle smoothly at first, when new?
REASON I ASK- after a couple 2500 rpm shifts, then back to idle, the truck will BOUNCE on idle, 775-900-800-875-825- then levels out , you get the picture... but a new HO/6-spd also did it here at work, it had 150 miles on it...
what gives?
First of all, I love my 4:10s :D
It's been mentioned on TDR before that the Mighty Cummins is designed to run at or near redline all day long. (stopping for fuel when necessary, of course):rolleyes:
Mine's running to the mountains this weekend hauling only my big behind and Wifey.
65-85mph for 200 miles.
It just blows the city cobwebs out of it. ;)
I have the 4. 10's with 265 tires and it works well for me. The RPM's will not hurt the enigne. I think that mine runs quieter now that is has over 14K on it.
The 4. 10's sure do pull the 5er nicely, and I'm getting 18 - 19 MPG driving empty on the local interstates.
good luck.
