About 3 weeks ago I had to fix the fuel heater on the fuel filter housing (replace the o-ring). After buttoning everything up had trouble getting the truck to fire off. Finally cracked the 1 & 3 injectors and cranked for a bit and finally got it to start. Truck ran fine for the next two weeks till a couple of days ago. Went out to start the truck, and no start. Good LP pressure. Took till the third ten second crank for the truck to fire up and it ran great with no problems. Stopped the truck and it would start back up several times with no problems. 2-3 hours later it started after about 8-10 seconds of cranking. Next morning, same story as the first time. Finally have it narrowed down to the 1 & 3 injector lines. They're both leaking a drop or two of fuel every 20-30 seconds while running. I've loosened & re-torqued both line nuts and still leaking. Other than the crossover tube o-rings, is there anything else I should consider as the cause of this? I'll be headed to cummins wednesday to pick up a set of six of them. Going to replace all of them at once. I have a part number of 3882589 if anyone is interested to know.
Thanks
Craig
Thanks
Craig
