My truck stumbled and died like it ran out of fuel while it was idling in my driveway last week, and I'm trying to figure out what its problem is. I was hoping you guys might give me some ideas that I might not have thought of.
My gauge was showing zero fuel pressure, but I didn't trust it--it's a mechanical gauge with an isolator that looses glycol over time (found out later the rubber diaphragm had a small hole in it allowing the glycol to bleed back into the fuel line while the truck was off). Since I wanted a different gauge anyhow, I ordered and installed an electric gauge. It showed about 2 psi when I bumped the starter to get the FASS pumping. After changing the filter and verifying the regulator spring wasn't broken (and I stretched it a little bit, maybe a millimeter or two), I'm now getting about 3 psi.
JR2 has kindly offered to loan me his pressure test gauge, so that'll help me verify whether my new gauge and/or sender is good. If it turns out that 3 psi really is what I have, then I'll need to start troubleshooting the FASS. This coming weekend I'm planning on pinching the return line where the regulator spring is to see if that causes a bump up in fuel pressure. Doug from Smokindiesel.com suggested that one (awesome guy, by the way!)
Do you guys have any other troubleshooting tricks or hints I might try?
Thanks,
Mike
Thanks,
Mike
