We put a steel braided line from the pump to the isolator for the fuel pressure gauge. It was fairly long and the way we installed it, it went towards the bottom of the drivers side battery. I guess due to the vibration, it worked its way under a rubber boot on a power connection (not sure what its called) just below the battery, and shorted out. It burned a hole thru the line, and the stainless line from the hole back to the pump had turned brown. Coulda been bad. Luckily we were under the hood and noticed the fuel leak right away and shut it off. Imagine if the hood had been down and we drove off.
Be sure and check the routing of your stainless steel lines.
For what its worth... .
Robin
Robin
