I had a 12 LML that had a hydroboost leak. The leak ran under the carpet and smelled inside the cab. So this is an inspection i do when i change the oil on my 15 Ram 3500 Cummins. The brake pedal rod goes into the hydroboost. At that seal i got one small/questionable drop of red fluid on a paper towel. The area looks shinny and wet but is dry to the touch. Where the plunger goes in i can see the slightest fluid around the rod.
I am in no hurry to run to the dealer if this is typical. I know this is not a normal inspection most guys do. The fluid level is at minimum cold and just below maximum when hot. So my question is is this normal? Possibly "assembly" lube? The truck is currently at 23,000 miles. A dealer trip will probably end up being several trips. One to inspect. One to replace. And at least one to fix the things they mess up while my truck is in the shop.
Does anyone here do this inspection and what does yours look like?
Thanks
Thanks
