Found a possible source of noise in the front end of 2 wheel drive trucks. (at least the 93's) When turning out of the drive way I had a clunking sound in the front end. Took a hard look and found the bushing on the right side strut rod to be demolished under the metal washer. Changed the bushings on both sides of the truck as well as installing new sway bar bushings and links. Seemed to eliminate the "clunk".
Note: Got the first set of strut rod bushings from NAPA. They will not work on the truck and went to the dealer to get OEM stuff.
(Took em 4 days to get the right stuff for me!) Also had to get the links from Dodge and the sway bar bushings for the link to bar connections.
I have all the ball joints and control arm bushings and will be changing those when the truck comes back from getting the new head stuff done. I also think one of the ball joints I got won't work either. Don't remember but I think it is the top one. Will also put in new springs at that time. That should take care of the handling issues for a while. I'll report on the results of that when finished.
