ok guys im new here i have a 2001 dodge ram reg cab 4x4 47re 24 valve. my problem is the trans i had a 2004. 5 dodge w/48re before this truck and converter lock was so much better. its so bad to the point where i dont think its locking at all. at 70mph i can let off the throttle and get back in and rps will raise around 700 before it starts to pull again. in the 48re when it was locked you hit the go pedal and it went. does it seem like this is a problem?? im not familiar with the way the 47re works, i tried a lockup switch and can not feel it lock up at all. checked codes when i uninstalled the lockup switch and it threw two trans related codes, i cleared them and they havent came back. i put the smarty on and anything over sw3 and "slides" into second gear. a trans is in order real soon, i just want to tie up any electrical grimlins that may be with holding lock up. thanks,
james
james
