Post Injection Pump Replacement Help
Bullydog Watchdog Performance Monitor
Timing Only Fuel Economy Module
After getting my injection pump and fuel rail pressure sensor replaced last week I was finally able to take it for a run. It's got some problems.
1. It idles badly. Stumbling, missing, and surging.
2. It sounds more like a '98-'02 24 Valve than a common rail.
3. It doesn't hardly have any power to get out of its own way. On a run on the freeway from 60-80 in 6th gear my EGT's maxed out at 768 and boost was a max of 17PSI but was mostly at 16 psi. This was at operating temp, fully warmed up.
Also, the following codes show up:
P0088 Fuel Rail Pressure Too High
P0148 Fuel Delivery Error
P0251 Injection Pump Fuel Valve Feedback
P6336 (I have no idea what this code is for)
I know the fuel rail sensor was a used one, not brand new. Not sure about the pump but it looks like a reman unit.
Any help would be greatly appreciated. The new baby came last Thursday, 3/11/2010, and I don't have much time to troubleshoot.
Thank you.
Mark.
This sound Like The discharge ball is sticking... Never I and I Never buy injection product for 3gen unless you know its origrin. I will try to help 763-228-7121 ,I don't type well.
Thank you Mr. West. I will call tomorrow. I'm too wiped out to even think about it right now. I did not do the work on this. A friend that owns a shop did the work.
Sorry Mr West. I had a situation I had to deal with. Sick kids come first. I will call when I get a few minutes to spare.
Just to close this thread;
It turned out to be a very dirty electrical connection at the FCA causing the issues I was having. Truck runs better than it ever has now that the connection is cleaned.
