POST LUBE
spray on liner vs slide in
Fifth Wheel Use on Short Bed
Looking for info on a post lube system. Electric lube oil pump that helps cool down the turbo after the engine is shut down.
99 TURBO 4X SLT 5SPD LB
Don't forget , the oil/bearings are only half of the hot stuff that needs to be cooled. The turbine fins also need to be cooled, and the best way to cool them is to idle the engine.
Several timers are available to allow engine to idle for a few minutes then auto shut down.
99QC,5sp,3. 54,stock,24,500 miles-11-25-99--EX phord owner
15-16. 5 MPG hwy ,14-15 city , 10-12 with 4,000lb TT
You might find what you are looking for at www.enginelube.com I had one of the prelubers on a previous truck for about 4 years and it worked well. Others have said that they aren't much good. Check it out.
