Post to readers rigs
other forum
Icons?
tried to post some jpg's to the forum, about 552 KB in size and this is all I get:
File upload error: none
Check the following:
Image file size may have exceeded maximum file size of 122800 bytes.
You have a very slow connection and the upload took more than 30 seconds. If this is the case, you'll need to upload smaller files.
You didn't specify a filename or you specified an invalid filename.
and nothing in the album, what am I doing wrong?
TIA
Disregard I'm only exceeding the size limitation by 430 KB... ... . Dough!
The size of your image file has to be under 122,800 bytes. You need to use photo editing software to either resize your photo or to compress the image so that it will be under that. I usually use .jpg files and set it to a quality of level 5 (out of 1-10) and can easily get under the 122,800 with an 800x600 picture.
