anyone that is running a 4bt (no 6bt's) please post pertinant information here so people can see what works, and maybe save some money/time by following known gear combinations:
(copy my bold template and add/change info so its kind of standard)
ENGINE/CPL/HP/TQ 4bt/858/105/265
Inter/After-cooler NO
Transmission/overdrive ratio 2wd NV4500/. 73od
Transfer Case/low range Divorced np205/1. 96to1
Axle Ratio 4. 56
Tire Size 38"
Vehicle Weight 6280lbs total (3780front axle/2500rear)
Fuel MPG ?? 24+mpg@70mph/30+mpg@55mph
no complaints, although flat towing a 6000lb vehicle maxed the truck out to about 60mph. i have since downgraded to 35" tires that are 1/2 the weight of the 38's. the truck accelerates faster.....
the swing in my mpg is rpm swing, not a true hwy city comparison
Axle Ratio 4. 56
Tire Size 38"
