Potato Canon
What's Your Favorite Cartoon?
Do you think that you sound like the people on television?
Is it CANON or CANNON?
It it POTATO or POTATOES? :D
Who's got a potato canon? How did you build it? Any advice? How dangerous are they?
Doc
Its a potato gun! Get it right :)
I made one once that could and it went through a wood fence :) repeatedly. Is it dangerous? No more dangerous then typical childhood things... :)
Let the Idaho guy set you straight... ... ...
It's a Spud Gun !!
PVC pipe, fittings, and glue. BBQ replacement igniter. Lotsa fun. Doc, search the net - there are some really good websites.
Dangerous ? Of course, but a little common sense (Don't point it at your brother-in-law !!) and you'll have fun.
Joe
We used to have a cannon made from PVC pipe and fittings. Started a 4" towards the bottom and reduced to the size of a pringles can at the top. Has a "T" piece at the bottom with a screw in cap, and a hole for ignition.
Use calcium carbide and water. Makes accetlyne ( sp? ) gas. Same as what the old miners lamps used. Can get at hardware stores.
several inches of water in the bottom. insert ammo at top. open cap and drop in a spoonfull of crystals. wait 20 sec. light.
Make sure to wear ear protection, and have the ignighter at the end of a long stick.
I don't know if this counts but. . .
When I was about 10 yrs old, my father was stationed at Forbes AFB outside of Topeka Ks. My friend David Kagarice and I use to fish crawdads in a stream by the golf course after collecting and re-selling all the golf balls we found. We would sit there on this old broken concrete culvert that was half burried in the ground. One day while at the culvert, we got a little bored for a lack of catchin' crawdads, which was directly related to the fact that we ate all the hotdogs we were using for bait, and the imagination of ten year olds reached knew heights!:rolleyes: You see, David was the Idea man and I was the, ahem, Engineer. David couldn't help but notice how much this culvert looked like a cannon! Well, I immediatly ran some calculations, figered trajectry, wind velocity,projectile velocity, and came up with a supplies list. According to my calculations, with one small bag of Kevin's (my neighbor) fathers reloading powder, a masonry bit in a hand drill, a string wiped down with black powder, we could probably launch a bowling ball (borrowed from the base bowling alley) accross three fairways and safely land the ball in the opposite field where we could recover, clean and return it to it's right ful owners. :rolleyes:
It took the better part of 4 hours to hand drill that hole in the culvert. I hadn't figured on wire reinforcement. Againsed my initial advice we went with a seven pound ball, David suggested it is easier to run with a seven pound ball as opposed to a 14 pound ball. We figured there was about 5 feet of culvert buried in the dirt so we had to do a little back-filling, probably a good thing we did. We snaked the fuse from the little sack of black powder (I'm sure it wasn't more than a pound or so. . . ) through the fuse hole then shoved the bowling ball in. It was a little tight but a pretty good fit over-all. We were ready. . .
We decided that safety was of the utmost importance so we should probably wait until the guys on the green tee'd off and got a ways down the fairway. We also figured we should be well behind the cannon once the fuse was lit. Ten yards oughta do it! The fuse was lit and we were at our battle stations, palms were sweatty and hearts were POUNDING. KABOOM! It felt like I got hit in the face with rock salt, but we did see the "cannon ball" fly. I counted 4 distinguishable pieces David claimed more. Of course I was never sure he could really see anything past a few feet with those coke bottle glasses! Considering the amount of noise, flames, smoke and dust particles that remained suspended in the atmosphere, we decided that there was only one thing we could do. . . Run like hell!
We heard sirens for most of the day. David and I spent the next few hours trying to figure out the answer to those unavoidable pending questions, 1) What did you do today? 2) There was an explosion by the golf course today, do you know anything about it? 3) Do you know why Kevins father would be in his garage screaming something about blackpowder when he came home from work? and 4) What are all those littld cuts on your faces?
Sorry Doc. I don't think I should help you out with this one. . . :D
Newf Limo,
LMAOROTF!!
A friend lives on the approach to the local airport and has a 'Wings of Freedom' party every year during the airshow.
They use a spud gun as AA but have yet to bring down a bird. The typical PVC config but instead use white gas to fire it. Couple shakes to get a good vapor cloud inside the tube and BOOM.
I saw a pic of one that was a machine gun. 6 spud guns mounted like Gatling gun barrels with a distributer from a 6 cyl engine running plug wires to spark plugs,one for each gun. Spin the shaft and watch em go. ;)
I Got one!
Doc- I made mine from Schedule 40 PVC It's over 5' long with a 2. 5" Barrel that threads in to a expansion chamber and can be broken down for easy storage.
Spud gun
A few years back I got bored at the restaurant I owned and made a spud gun outta a pipe (stolen from the coat rack) and some pipe fittings hooked to a co2 bottle. (from the soda machine) only shot about 20 feet though, the valve on the co2 didn't open fast enough. I saw on the internet a stupid thing I just had to try Called a ball buster i consisted of a short piece of pipe with some fins on one end and a 12 ga shot gun shell on the other and a nail for a fireing pin. when thrown in the air the nail hit the ground and pop. I never tried it with live ammo but it would pop a primer. Like I said stupid!
Oh yeah more stupidity
This is called a Kitchen racer, take a 2 liter PLASTIC soda bottle and drill a hole through the cap put some propane in the bottle (a BBQ lighter is good) put the cap on and put a flame at the hole. it takes some practice to get the right amount of gas in the bottle but when you do the bottle will shoot across the room with a cool blue flame shooting out the back!
Ps the bigger the bottle the better it goes. just be sure it can handle the pressure. ... ... a 5 gal. frying oil container cannot, trust me.
ah, the good old days
Karl2500,
Reminds me of back in high school when we used to smoke those left handed cigarettes. By buddy Kevin, had an attic we used to sit in. He used to take a pop bottle hold in upside down. Turn on a butane lighter and let it fill. then hold the bottle horizontal and light. Poof, has a cool flame shoot out the back of the bottle.
One time no one paid any attentiont to how long Kevin was holding the lighter open in this tiny attic. When he lit it the entire attic when poof. burned the hairs on all of us sitting in there.
I've got two spud guns in the garage right now, a "regular" and a "bombed" spudder. I chronographed one spud at 318 fps. You can put about 1/2 of a paper towel in the barrel, spray it with wd40 and lighter fluid and make the spud into a tracer that will burn for about 75 yards. Experimenting with my "magnum" I actually blew out 6 rivits that held my piezo ignitor to the gun, so yes they can be very dangerous. The best propellant is WD-40 because it doesn't gum up the loading plug and gives the highest velocity spud. The best ignitor I have come up with is the Coleman lantern lighters that use a striker similar to a cigarette lighter. I don't think there is any doubt that an 8 oz spud at about 300 fps would actually kill someone if it hit them in the head so you do have to use a little care in where the barrel is pointing when you pour the coals to it.
There should be a version that uses compressed air and an inground water sprinkler system solenoid for a firing device... ... a friend has one... . I got to thinking this would be a great "less lethal" device for the cops, so we dressed his kid up in his catchers outfit (can you see this coming) and stuffed a raquet ball into it... ... :eek: at 50 yards it nearly tore his head off! You don't need the hairspray ones to make a real weapon out of them!
I had one a few years ago but the cops that cought us shooting it did not find it funny. The damn thing sounded like a canon when it went off and I guess the neighbors did not like the noise at 1:00AM(go figure)! I tried to hide the spud gun when the cops showed up but I forgot about the 40 pounds of potatoes and 5 cans of hair spray sitting on the hood of the truck(DOH)!!! I tried to tell the cop that we were just having a potato "roast" but he did not buy it. He found the spud shooter and man I thought we were screwed. After I explained why I had lied to him he told me that these things are illegal and I could be charged with a felony. He took our licenses and sat in his car on the radio for 15-20 minutes, the whole time I was thinking we were going to jail! He ended up giving us our licenses back and taking the spud gun and the hair spray, plus all the spare parts for our new gun we were building and told us we could go but that if we got cought again we would not get off so easy. The next day I built a new gun but it stays at the cabin, no sense in going to jail over a toy!
I was up camping with my buddy one time and we got to shooting off the large caliber spud gun in the forrest. I have a smaller caliber "magnum" version too.
Seeing as how it was hunting season and we were both licensed, I bragged as how I ought to shoot a squirrel for dinner. Troy bet me I couldn't, so I strolled over to a big pine and waited patiently.
Presently a squirrel showed himself and and, using imaginary sights on my hairspray-powered cannon, I let him have it. All three of us were surprised when the squirrel went squirting out the far end of the tree, graveyard dead.
Fully intending to make good on dinner, I retrieved him, only to find he was not big enough to make a spoonful of soup.
What to do.
Well, we needed to get it out of camp before it started to smell and the dogs got into it. Somebody made a comment about flying squirrels, and it sorta went downhill from there. He did fit in the two inch barrel and, using another spud to get a proper seal, we gave him a flying wake.
It worked entirely too well - his tail was spinning like a propeller and he went a good hundred yards from camp.
We laughed about Rocky the rest of the day. Troy has a way of telling the story that still makes my stomach hurt...
