I'm really looking at purchasing a new GN trailer here in a few months. I will probably order it and pick it up late winter I'm guessing.
So I've narrowed it down to DiamondC and probably their FMAX212SS
I'm going to get the 12' hydraulic dovetail and either 18' or 20' deck for an overall deck length of 30-32'. I'm also sold on the super single version of this trailer. Less tires and it looks "stealth." The dealers all agree, you get a lot less attention from DOT and others because the trailer doesn't have duals.
I am debating on HDSS suspension option vs regular. The HDSS looks a lot beefier and allows independent axle alignment adjustment. I'll probably check the box.
Next is the brakes. This won't be a highly used trailer and I don't plan on loading it to the max GVWR all the time. I haven't priced the electric over hydraulic disk option vs the standard electric drums. I haven't pulled a trailer with electric over hydraulic disks. This option is expensive and fairly complicated. I really want you opinions on this.
Is it worth the upgrade to go 12" OC vs the 16" OC for the trailer decking braces?
What about the decking itself? There's a few options here. Standard planking or Oak? I don't plan on hauling tracked equipment, but I'd like to have durability.
Spare tire, check.
Winch plate and receiver hitch, check
Zig zag screws, check. (more screws in the deck boards to trailer framing. Not sure why this isn't standard.)
More marker lamps, maxxed out option, check.
Custom paint to match the truck, check.
I *may* purchase another under-mount toolbox for the curb side.
Thought and opinions are appreciated.
Spare tire, check.
