DPKetchum,
The tamper cover on that screw should just pry off. It is a bit tough to get off sometimes, but it will give. It has a little spring clip inside that keeps hanging on making your life difficult.
When I got mine off the first thing I did was make a small punch mark on the small (6mm) end of the adjustment screw. I used a spring loaded center punch used in aircraft work. Whatever you use, just make a permanent mark for reference. ( Also make note of your RPM before you start this. It can also be used as a reference later. )
Then all you need to do is loosen the lock nut (13mm) and turn the screw in. On some pumps you may find that the lock nut can't be backed off more than a turn or so before it hits the tack welded tamper ring on the screw, which means you can only turn the screw IN one turn.
If you are determined to remove the lock collar then carefully loosen the locknut just enough to move the screw, back the screw out carefully and mark the position of the locknut before going any further.
That way you know roughly were to turn it back in to, when you reinstall it, without the lockcollar.
Is this making any sense???
BTW, the small hex end of the adjustment screw is a 6mm.
To remove the lock collar you will need to file or dremmel the tack weld on the thing.
Once that is off, position the locknut by using your reference mark, and screw the thing back in.
Snug the locknut, and start truck. Check idle RPM. If you were carefull when you marked the locknut position, and put it back right, and your RPM is the same... your good to go.
Often when the full fuel screw is adjusted inward past a certain point the idle will climb above pre-adjustment level.
One CTD'r told me he loosened off the locknut just enough that he could move the screw with his 6mm socket. Before moving anything he put some of that putty stuff you use to stick pictures/posters up on drywall, and wrapped that around the locknut/screw so it was "stuck" in place as he removed the screw.
I just counted how many turns the locknut backed out till it hit the lock collar, then reversed that process when finding my starting point prior to removal.
Ok, if you find that you adjust the fuel screw and your idle goes up you may need to adjust your low idle screw to bring it back down. Usually around 750-850 is good.
If your timing is set right (1. 45mm or 15*advance) you should tune the fuel to your personal preference.
Generally you want low/no smoke at idle, boost 25-27psi at WOT empty, and EGT's as low as you can get them, with 1250*F MAX
Remember when loaded and pulling hard you will see higher boost and higher EGT's so if you are hitting 1250*+ now, empty, you'll see more if you pull a hill loaded, and at WOT.
I'm sure I made this too complicated but I hope that it helps a bit.
If you have more questions, just ask...
Clear as mud, right...
Bob.
