Power edge comp & 275 RV inj. make 401 HP
Computer DTE (Distance to Empty)...
Mallory 4140M
That's right , nothing short of awsome this new comp box is the real deal. Dynojet numbers 401. 9 HP/ 851 ft. lbs. I made a total of six runs with various power/smoke settings and found out something most of us probably already know, no smoke (fuel) = less power.
That same evening after the dyno runs it was off to the track. The last time at the track the truck ran a best time of 15. 52 @ 86 mph, that was with the EZ & power edge. I was hoping to maybe go a high 14 with the new comp, once I figured how to launch the truck without totally smoking the tires the truck ran a 14. 37 @ 94 mph. Gained over a full second and 8 mph in the qtr. ml.
I thought these numbers were impressive considering im still only running 275 RV injectors, wonder where some big nozzles & HX 40 would put me :D Thanks to all at Edge for making quality products, Stefan thanks for hooking me up, and Willie at Lujan Motorsports for the dyno runs and anything I need , performance or diesel
well done, I have often thought of dumping my PM3 for a PE comp.
maybe someday I will get a chance to try one out and see.
I assume I am close to you with my PE COMP and DD1's.
Also a BHAF, and a very free flowing exhaust.
I really like this 400HP thing,, to bad my clutch doesn't hold all that great in 4th gear.
MerrickNJr
Holy Horsepower Batman!!!!
Awesome Wayne!
I just ordered an Edge Comp myself from Stefan of DTT yesterday (this will replace my DD True Torque Power Module... which is already spoken for :D ).
Since I have already purchased two different hard core fueling boxes that I never actually installed (Edge PE and PM3) and subsequently sold :rolleyes:... (I was ultimately too chicken to hook up the pump wire to my '98. 5 VP44). Well, I finally decided to go for it! And just in case my semi-early VP44 goes TU I have enlisted the help of my very good friend Rob Hanson and his flat bed trailer to haul my Ram as required.
Da*n, it sure is great having good friends! :)
PS: I sure hope my OE VP44 is my "good friend" too. :D
