Dave, I'll have some EGT temps while towing for you after this weekend. Got some EGT/Boost guages installed yesterday and couldn't get it over 1000 degrees (the exhaust is straight piped). I'll be hauling 3 of 4 horses to a roping down in Chatsworth and on the way home there's that grade up the 14 then I get on the 138. I've towed up this same grade without the RV injectors and the PE box with 2 horses and downshifted to 5th gear to keep my rpm over 2000 rpm, it felt like the engine was starting to lug in 6th doing 70-75. The 01 will easily run up to 3000 rpm no problem while my 95 is hard to get over 2500 rpm and runs fine right around 2000. Driving the same road with the 95 I never drop out of 5th and can't get my EGT's over 1100 if I try. I'll report back sometime Sunday with towing temps in level 3 unless for some reason that it's running too hot then maybe I'll drop down a level or two but I doubt it. Still need to see why it's not getting enough boost though, only 23 pounds when a few folks say it should be getting 30+.
Kyle
2001 Dodge Ram White 2500 Quad Cab 4x4 24 Valve Cummins 3. 54 6 Speed Manual, Alpine CDA-7863 60Wx4 CD Receiver, Cup Smoothie, 285/75/16 Dunlop Radial Rover A/T, Chrome Westin Step Bars, PowerEdge Module, 275hp RV Injectors, Straight-piped, TNT Spray-in Bedliner, Tint, DeeZee D. P. Toolbox, Bugshield, Cody GN Hitch, Tekonsha Sentinel Brake Controller
1995 Dodge Ram Black 2500 Club Cab 12 Valve Cummins 3. 54 5 Speed Manual, Ventshade Door Sill Plates, TST Kit/AFC Spring, Tekonsha Sentinel Brake Controller, EZ Drain Plug, GTS Sportguards, Tint, Wilson 3' Antenna, Cobra 75WX ST CB, Better Built D. P. Toolbox, Bugshield, Alpine 3 Disk In Dash Changer, Cup Smoothie, SS Rocker Panels, Ultimat, Combo Guage, Airlift Rear Air Bags, SS Bed Rails, Eagle Alloy 16x8 1189, Bedliner, GN/BP Hitches, 4" Downpipe/Exhaust System, Husky Floor Liners
1993 Dodge Ram Red/Grey 250 Club Cab LE 12 Valve Cummins 3. 54 4 Speed A/T, Chrome American Racing 16x8, Banks PowerPack/Quickturbo, PacBrakes, 6 Disk Kenwood CD Changer, GN/BP Hitches, Tint, DashCover, Bedliner, Boost/Pyro Guages, Alarm/Keyless Entry, Weatherguard Toolbox
2000 Exiss SS400 4 Horse GN Trailer
1996 CM Brushbuster 16' Stock GN Trailer
