Power Edge EZ question
filtration
I would like to get some information about how the Power Edge EZ box works and just what it does for the 24 valve cummins. I understand that it increases timing. Does this change in timing vary with rpm change only or does it also vary depending on boost/load? Does it also increase the amount of fuel injected? And is it RPM dependent only or boost/load dependent also? Does this box affect the amount of boost that can be reached or does the elbow included with this EZ box just fool the trucks ecm to sense that that the boost is lower than it actually is? I hope these are not stupid questions I just want to know how this box really works. I could just call Edge Products but Im sure some of you folks can tell me this stuff.
Thanks
Ken
1998 1/2 24 valve 2500 automatic 3. 55 alcoa aluminum wheels
Ken, the EZ does increase timing and fueling, but not past the specs of the injector pump. I believe it remaps up to 2500 RPMs. The boost elbow allows higher boost, and the boost module(part of the EZ) fools the ECM so no over boost codes will be sent. It does this by clipping the voltage of the MAP sensor.
I can tell you it does make a noticable improvement. It wakes the truck up.
Fred Swanson
Co-Owner
Canyon State Components, LLC
'00 QC,SB,4x4,Auto,3. 54 w/LSD,Trailer Package, Tow Package, DTT's VB & TC
[This message has been edited by cscpusher (edited 12-31-2000). ]
Ken, I'm running with just the EZ now in my ETH and can tell you that it really wakes up the engine, a real kick in the pants, IMHO. Stock, the best I would see is 20. 5 psi from the turbo. With the EZ and it's replacement elbow, I now see 28 psi's at WOT. The egt's come up faster but I have never gone above 1100 F at the manifold (pre-turbo). Hope this helps.
Scott W.
White 2001. 5 3500 ETH/DEE 4X4 Quad cab SLT,tow package and camper prep,Husky liners front and rear,DiPricol pyro,boost and oil temp gauges,Edge EZ,Mopar tonneau,Lund bug shield,PM tractor utility back up lights,Penda bed mat and blow by bottle is bye bye !!! I love the smell of diesel in the morning, it reminds me of... . VICTORY !!!
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089608" TARGET=_blank><font color=red>My Truck</font></A>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089604" TARGET=_blank><font color=red>THE SAINTS</font></A>
<font color=blue>Why not just give Brett or Taylor at Edge a call and have them answer your questions. After all they built it, who better to tell you what you want to know.
They will be happy to talk to you. If you need the number let me know.
