Started having a problem with my truck loosing power. The motor will not accelerate, no smoke, no boost. Other times the truck screams like normal. When it is running bad it idles fine. No codes are being set. 1 month ago relocated a new lift pump on frame. FP is 13. 5 to date. Tried to disconnect EZ with same results.
Truck is a 99 with EZ, exhaust, and cold air kit.
Is the VP going south? Is there anything else to check before this expense?
Thanks Ronnie
Thanks Ronnie
