I have a d70 with a stock Power Lok. The diff was starting to lock on tight corners, so I put in more friction additive, didn't help. I pulled the diff cover and everything looks pretty good. That is, except for the play inside the Power Loc. As I rotate the wheels back and forth the rods engaging the carrier move in and out almost 1/8". Ummm, gussing that that is not normal. Given that, I have 2 questions:
1. Should there be play inside the Power Loc?
2. If it is too loose, am I in danger of grenading the diff if I fill er back up and drive for awhile?
Thanks!
Thanks!
