Engine/Transmission (1998.5 - 2002) Power loss at 55 mph
2nd Gen Non-Engine/Transmission Ever try this exhaust
Truck loses power between 50 and 60 mph. Power comes back if throttle released or if I turn key off and on quickly. Also will not go over 40 mph on cold start. After about 5 minutes engine runs fine. Installed new lift pump and new batteries. No help. Fuel pressure at test port by injector pump is 14 pounds while engine has no power. I checked it after cold start in the morning. Some white smoke with throttle wide open and engine at 2000 rpm in neutral.
2001 stock. service bed and crane.
Originally posted by Snow man
do you have any codes?
No codes. I did take it in to the dealer. They kept it all day. When I picked it up that evening, they said they never had time to look at it. I have to have it to work.
