I have a good one for you experts on the forum. Sorry for the long post but I figure the more information you have to go by, the better.
2003 Ram 3500, 5. 9 CTD, 47RE trans, 148,000 km (90,000 miles).
When I bought the truck Apr 2006 it had trouble maintaining 100kph (60 mph) on level pulling 14,000 lb 5th wheel RV. When I returned home I tried the trial chip from BullyDog. The truck ran great even after the chip trial ran out. We travelled 20,000km (12,000 miles) across Canada summer of 2006 returning end of Oct, no problem with power. Over the winter I noticed that the truck was losing power. I thought it may have been the winter fuel or the short trips. The power has not returned during the summer, if anything there is even less power.
I have taken it to the dealers and all they do is charge me with no changes. I took it to one diesel shop and he changed the intank fuel pump back to the out of tank pump. No change. They were unable to discover the problem. I have now taken it to another diesel shop. They have tested the injectors, within spec. There are no codes. He noticed that there was about 28 lbs of boost so he thought the MAP(?) was causing it to defuel. They are now taking the turbo off to see if the wastegate is sticking to cause this to happen, no word yet. Dodge dealer says there is enough preasure going to the injectors. I have not had the valves adjusted, would this make much of a difference on power? The truck starts well so we feel the compression is good. I have not changed the fuel filter. Fuel mileage is about 17 to 20 mpg. EGTs are around 5 - 600 normal driving, may go to 8-900 with heavy foot.
I had bought the BullyDog PMT as in stock mode the truck had trouble pulling the trailer. With the PMT the tow mode does add some power, however the performance and extreme modes have no additional power. There is no smoke what so ever on any of the settings.
Hope you guys can help.
Richard
Richard
