Like others have said, check/clean the master panel switch first and plug, but then ALSO carefully inspect the wires that run from the door controls to the door INSIDE of the black rubber loom.
IIRC, You need to pull the loom back from the pillar side of the plug` and then CAREFULLY inspect and even PALPATE each wire. Sometimes the break will be obvious, but other times, there wire can be broken UNDERNEATH the insulation and you can't see it, but you can FEEL it as hard, brittle spot where it is failing from wire fatigue. At least that is what happened to mine.
