Power pup
Edge Juice/Attitude Question
Report from new 05 owner
I have been using the performance mode with my 04, 373, 6 speed. The mileage have been the same as stock... ... . when I keep the right foot out of it.
"I have been using the performance mode with my 04, 373, 6 speed. The mileage have been the same as stock... ... . when I keep the right foot out of it. "
mr. billh,
I don't think I have ever seen that option in any of my bombs..... I usually can't find the self control switch either. :D
Kyle: I recieved the pup with monitor from you a few days ago. I just installed it. The performance is great. I noticed that the overhead milage has lost at least 2-3 mpg. I have only ran it for 20 miles and I havn't been able to calculate the milage. I wonder if the overhead will be off that far or if I have actually lost that much milage. I am running it on the 90 hp setting,
2004. 5 2500 quad lwb 4X4 auto 373 afe air system
it seems as if the 90hp performance setting is where my best mpg is also.
a friend has a pup on an 04 and making 2 identicle trips with same trailer he got a 2mpg increase in the perf mode compared to stock
I have been tracking my milage since I got my truck and I have noted what level I have my PUP set on. I only change programs when I fill up. I always return to the stock setting every other fill up so that I get can track other changes to the engine and drive train. I have not used extreme level because my clutch doesn't like it.
I think I am getting the same fuel milage no matter what level program I use. I use more peddle in the stock mode, which translates to more fuel used. In performance level I don't use as much peddle, but then I don't have to. When I save up enough for a clutch I will probably use extreme mode more often.
