About three weeks ago I siphoned out the factory power steering fluid and replaced it with synthetic. I went for a test ride and had no power assist in the steering or brakes. I had inadvertently overfilled the tank, so I used a turkey baster to suck out some fluid to the proper level. This worked fine for the next three weeks. The temp dropped a few times and I heard the infamous growl, but it was significantly better than before. A few days ago the temp dropped well below 20* and I did not have the heater plugged in. Once again I did not have any power assist, and the PS pump puked a fair sized pool of fluid. I again sucked out some more fluid, however I still have an annoying sound and lack of power assist. Before attempting to fix the infamous growl, it would make the noise predominately when steering and somewhat during braking, experiencing limited power assist during those events until the truck warmed up and they went away. Now the noise is a much higher pitch, it happens while I hold the truck with the brake, and the steering resistance is intermittent (grabby). I have not yet driven a distance that I would consider the truck warmed up, but I have plugged it in a few times, and the outside temps are upwards of 30*. The feel and sound is similar to when it had stock fluid and cold temps, but noticeably different and does not seem inclined to go away. I also notice considerably foaming in the PS pump while checking the fluid level. Naturally I am worried about the first overfilling/short drive episode having caused damage that showed up three weeks later. Any suggestions???
