My power steering pump has been growling for over a year. I've known it leaks for a long time, because when it makes a lot of noise, I check the level and it is low. After being filled up, the noise is usually gone for maybe the rest of the day. I have lots of oil spots in the driveway and undercarriage covered in oil.
I've noticed that the spots on the driveway and all over the undercarriage are not just steering fluid. There is also a healthy amount of engine oil leaking from somewhere. I've not found any evidence of leakage above the engine fan. Mostly low, and around the steering pump.
I have a new PSC steering pump that came with some new o-rings. What I'm wondering, is if both steering fluid and engine oil could be leaking from the same place? I've had no problems with my air vents so I don't suspect any damage to my vacuum pump. But I'm thinking a seal in front or back is probably the cause of my oil leak.
Could steering fluid be leaking from the same back seal? Does anyone recommend a reliable shop near Salt Lake City, Utah, Ogden, or South Western Wyoming? I've looked into fixinrams.com parts and am wondering which products I need to fix this and keep the leaks from reoccurring.
