Archived power steering fluid ?
Archived 2002truck died at finish line, wont start help!
Archived bought fuel, drove 1/2 mile, now wont run!
does any body know what type power steering fluid goes in it i have a 2002 had same problem back 4 years ago steering wheel locked mechanic said to put atf-4 fluid oem manual says dont ?
Ramman,
As you noted, the owner's manual says not to use ATF-4 transmission fluid in the power steering. If you go to any auto parts store and check the shelf with the power steering fluids, you will easily find several brands which claim to meet or exceed Chrysler's (and other manufacturer's) OEM specifications. You'll also have a choice between regular, synthetic, or a blend of the two.
Best regards,
John L.
