I found using my Mighty Vac brake bleeder works REALLY well for removing PS fluid from the reservoir. If you "fish" the tubing around in the PS reservoir you can find a slot/hole which allows you to reach the deep depths of the PS reservoir. Then you just leave the hose in place and pump the fluid out, stopping to empty the collecting container. This method does not make any mess, as opposed to the first time I attempted a PS fluid change with the turkey baster method. Think I can usually get about 12 oz or more out this way and only takes around 10-15 min ( and I'm a SLOW worker) from the time I pop the hood until I button her up.
I use the Valvoline Syn-Power stuff, but was considering changing to a full synthetic fluid. Anyone have experiences with Royal Purple or Redline PS fluids??
Joe, I'm assuming the LE product is not a synthetic fluid. . am I correct? I know LE makes some high quality lubes, can you tell us any more opinions, etc about the LE power steering fluid.
