Other than the newly developed leak that I got in my vacuum/power sttering pump, I've been having an intermittent problem with the power steering on my 2001. 5 pretty much since day one.
What happens is that when it's cold (i. e. near or below freezing), even if I let it idle, it occasionaly acts as if the power steering pump is not there. This happens right after startup, I start the truck, put it in gear, start to move, turn the wheel, apply 50 pounds of steering force for three seconds, then all of a sudden the power steering pump decides to show up for work. After this initial problem, it works fine. I've checked fluid levels, etc... ideas?
