Check your brakes with the engine off. Use a large empty parking lot, roll at 2-3 mph, shut off the engine and try to stop. If the brake pedal is hard immediately with no brake assist, then the compressed nitrogen cylinder (blue anodized color) on the brake master cylinder may have burst. Pressurized nitrogen in the lines forces p/s fluid out of the reservoir. As the nitrogen works it's way out of the system, the fluid level will read low again. Something else to check.
