I lost power steering on a -20 morning 2weeks ago when i started my 2000 truck. Fluid was leaking out the pump where it goes into the vac pump. I removed the pump and found one of the mounting ears was broke on the vac pump. Installed both parts, a new vac pump and a rebuilt ps pump. Fired it up and had vacuum but no steering. Took the ps pump back off and bench tested it with a drill and it didn't pump. Tried another rebuilt pump on the bench again and it won't pump fluid as well. What am I missing, checking the pump this way should work or did I get two junk rebuilt ps pumps? If the hydra boost is bad would I still not have steering?
