The shop manual says to remove the pulley from the pump to get the torx bolt out. I pulled the entire pump/reservoir unit from the truck so I could work on it on my bench. I did not have the correct tool to remove the pulley and after trying a couple of pullers I had in my tool box I still could not get the pulley off the pump. I ended up taking a Dremel with a cut off disk and sliced off the side of the torx bolt. Not enough to get in to the torx bit area but enough to clear the pulley. When I put the reservoir back on I used a stainless washer under the cut torx bolt. The new O rings worked great. No leaks, not much money.
